I do a pretty quick oil change (50-100 miles) just to get all the initial wear-in particles out. They can cause secondary wear, and they can also weld themselves in high pressure areas, changing clearances and causing other problems.
Then I do a 3,000-mile oil change to see how the engine's breaking-in and whether the oil's doing well or not. If things look good, I extend my oil change interval to 5,000 miles, otherwise I keep it at 3,000 miles until I can find an oil that performs well. If things still look good at 5,000 miles, then I'll extend to 7,500 miles (or shorter if the on-board computer recommends less).
I send samples of my used oil to a lab and have a tribologist help interpret the results, so yeah, I geek out a little bit on it.
