definitely looks higher in the front, especially with a full tank,I can't remember what I was before installing RPG 1.5. If I recall I only got about 1" lift in the front which is okay as that is all it needed to look level. Mine is a 37 pkg if that matters. I also just put some true 37's on that added a little more height. As I measure today I sit at 43.20 on all 4 corners from ground to bottom middle of fender flare. Here is a picture for reference. The measurements change slightly depending on full or empty tank of gas. The best news for me is that it still fits in the Garage with about an inch to spare above the black fins on the rear of the roof.
View attachment 409936View attachment 409937
Not sure if you are asking me or So-Cal. Mine is 35x12.5R22 with +25 offsetLooks awesome!
Are you running +6 and 12.5’s?
i understand, and some trucks yield different heights. my truck happened to get exactly 1.5” with spacers and 1” with eibachs. what people don’t account for is lifting the front often lowers the rear due to weight transfer.I did just fill it up with gas in the picture, I only got 1 " of lift. I am happy with it. At certain times it can look back end high. I have stated before that if springs were out 9 months ago I would have done that, at the time this was the only option.
