EZDOWN TailGate Mod.
Humvee21
I'm trying what phyguy said but I'm just ******** into nothing??? I don't understand how this works
svt83
Wyoming
Put the nutsert in the spot. Use the Allen wrench to hold that screw in place, then use the 10mm wrench I believe to turn the nut 6-9 full turns depending on your truck. By tightening that nut it spreads the nutsert to stay in the tailgate
Humvee21
Oh... Thanks!!
TheJoker
N. E. Massachusetts
Ok I came to a friend's house to borrow some tools. I'm stuck... How does the nutsert go into the opening by the tailgate pivot point??? Is it supposed go screw in somewhere? I'm so lost...
The nutsert goes into the small oval hole about 5" away from the hinge. Once you tighten the nutsert as mentioned earlier the allen bolt, washers, roller, and nut are removed and discarded. What is left is just the threaded insert which gives you a place to attach the lower ball mount. Using a 13mm socket will secure the ball mount to the insert and secure the insert to the tailgate. I hope this make sense. I think its a much better design than the earlier version.
Humvee21
Yes, thank you guys for explaining this. Took me about a 1 hour install trying to figure that nutsert thing out lmao... I tightened it about 9 times, and still could not get the nutsert to sit tight in the oval hole. It just has a tiny bit of play, which I hope is alright.
RatedSVT
Sleepy Hollow,IL
I've got that too. Im sure it's not going anywhere though.:birgits_tiredcoffee
svt83
Wyoming
Not a problem! It took me a bit to figure it out as well since I have never seen something like that before. The rest was really easy, and it works great!
trentw12
Bay Minette, AL
thanks for posting this! i work at AUTOZONE on the weekends and was able to use that part number to get my kit! when i get back from Virginia next week it will waiting for me to install!! :waytogo:
