Exhaust rattle on cold start?
cr23raptor1983
Baltimore, Maryland
It sounds awesome and even better than before due to no restriction from the valve plates. Glad I did it
Your sounded like garbage because the valve plates are loose enough to make a slight fluttering noise on start up. Mine didn't sound good either on start up- but now it sounds pretty mean and(solid smooth sound) considering it's a v6
Raptorbert
Hampshire, IL
It'll come back... you'll see. Ashame I know
I went back a few pages and I mostly see “it came back.” Is it even worth going in for it? I don’t prefer it but I don’t want to waist my time. It’s no more annoying than the hellcat hemi tick which is considered normal.
ReLLiK75
Las Vegas, NV
Mine was rattling really bad and seemed like it was getting significantly worse. As of a few days ago, and all of a sudden, it stopped on its own. But, now I no longer have the ability to switch exhaust modes. It sounds like I'm permanently stuck in Baja mode. Not necessarily a bad thing, but I do like quiet mode for when I'm leaving the house at 5AM. Whatever is controlling the different exhaust sounds must have broken and in the process stabilized itself.
KODIAK
Add me to the list. Loud, rattling, ticking when started. Low RPM in higher gears and I get a hesitation and helicoptering sound when lightly accelerating. Dealer replaced left actuator, somehow made it worse. Going back in tomorrow.
flockofraptors
NJ
So, the noise is present initially on cold start, goes away once the idle drops, but then is still present under acceleration and load at low speeds (and probably at high speeds but I can't hear it anymore).
Definitely sounds like a rattle or just something loose. I looked underneath and didn't see anything obvious. It does seem to be coming from the valve area or the muffler canister right near it, but it is hard to tell.
I have tried the different exhaust modes and can hear a difference, so I think the valve is doing something.
Is it like this
jnrush16
Kansas City
Mine has started to rattle on cold start and goes away once warmed up.
I attached the TSB with specific part numbers for folks to reference. I bought the ford Premium ESP and the dealership is trying to say it’s not covered. Fix is going to run me $700-ish. Irritating. Anyone else had issues with it being covered under an ESP? My mileage is around 48,000.
FordTechOne
Detroit
Take a look at your ESP contract, it will tell you which coverage you bought. You can then either reference the brochure if you have it or look up the plan online to see if/what exhaust parts are covered.
jnrush16
Kansas City
Took it in for repair under TSB 23-2341, bought the parts myself (saved me $200), and they called today and said because my truck was produced after June 2022, they can’t replace those two parts. The whole thing needs replaced. $3,200 …They submitted a request to ford for “financial assistance”, because they claim the TSB is wrong, but I’m not keeping my hopes up. Been a very frustrating process and problem for a $70k+ truck.
