2025 RAPTOR R noise on cold start up? Engine or exhaust? Started@400 miles breaking in easy
DPGT
Philadelphia
my late late last week of November build RR same sound. I believe either the trombone and the opposite exhaust are hitting each other or it’s the flaps for different modes being in a weird spot upon startup
DPGT
Philadelphia
Anyone with the noise have their RR in the garage? If so do you ever hear it go through a check. Meaning where the valves are set when not running. My 21 GT500 CFTP does this randomly like a systems check.
Sabeous
Liberty Lake, WA
I haven’t had that happen on mine. Got mine back from the dealer today who replaced the valves, makes the same rattle noise if it is cold outside. Apparently Ford has said it is normal if it is below 40 degrees. Really considering an AWE or Borla cat back exhaust.
Speedracer800
I just got my 25 R, and came here looking for a solution as mine sounds exactly like the videos posted here.. Space White too!
My gut reaction was a belt slipping on cold start and I really thought that was the issue until reading info here supporting an exhaust problem being the culprit. I tried a little belt anti-squeel, (which I hate to use) but just to help diagnose and it seemed to make no difference.
Hoping everyone's right and it's proven to be only an exhaust problem. On a side note.. My "quiet start" setting doesn't seem to function at all. That's got me thinking about a possible connection.?
