Eibach Pro-lift springs installed with pics and comments
Carlos M
Will do, after I had the Eibachs installed on my truck I posted some before and after shots that are pry on earlier pages in the thread. I have a 2017 and I can say with surety I only got around 1.8 inches of lift. Absolutely positive I did not get 2 inches. The consensus is that it differs on a truck by truck basis because of other variables, such as rear leaf age etc.
I read your old post. You are sitting 1 inch high up front. I’d that still the case? Did they not settle some ?
Leftsidej
Missouri
I’ll re-measure when I get home. They have settled. I really like the setup. Would consider deaver +2 instead of 3 as I don’t tow anything
FrodoTBaggins88
US - Utah
Why is nobody talking about geisers ...haha...here is my geisers, icons, 37s, I put some rubber caps over my ubolt threads95e9f5fe4f44b2ef9e76e0c69b9fd500.jpgec969bbdf68f87a9e6c82c72f488ef6c.jpg8c99d4ccc8650a657e263969bc4c626e.jpg3bc86744c980f13a6397406df7084248.jpg25314c9cb8d7a38a9f420737c62a19da.jpg524a7cfc70c105396dbe0f6031a1689f.jpg905b73cf70c5a82985e4d67b1ea97b51.jpg9f957d25e3b06f6e56b89d57a0c89f12.jpg
Sent from my SM-N950U using Tapatalk
No one is talking about Geisers because the thread is called "Eibach Pro Lift Springs" haha.
That looks really good though man, nice truck!
Leftsidej
Missouri
Man, great look. That seems as level as they come to me. At least to the naked eye. I assume it did settle some.
Thanks man! Yeah I'd agree with that. In this picture almost looks like a smudge higher in the rear than front. I haven't had them too long either.
Carlos M
Good to hear and see. Once mine is done Wednesday of next week I’ll post the picture.
Thanks for sharing info and the picture.
Leftsidej
Missouri
Sounds good, no problem! Looking forward to seeing the picture. Make sure your installer has the right alignment specs for the Eibachs.
Trouble-T
NY
Just got home from having eibachs and Icon setting 1 installed on my 2019. I measured 7.5 wheel gap up front and ended with 9.2. Got exactly 1.7 as advertised. The rear went from 9.5 to 10.7 so just a little over the 1 inch advertised.
To be honest the suspension was real soft and drove so nice but now it is a little stiffer. I did not really want to lift it as I like it the way it was but went with bigger tires and need the lift in the front. I wanted to use spring rather than collers so had to do the rear too so it is not nose high.
If I could do it over I would have just kept stock sized tires and kept the suspension stock. Would have just changed the wheels
Carlos M
Man, sucks that you feel that way. I have done it in previous vehicles and had the same thought. I am trying to avoid the Icons but i know I will end up just like you.
If this makes you feel any better the truck looks great. Still, I know when you are in the driver sit that wont make it any better. Also, you will not regret that set up if you go offloading but for city driving i know it is not ideal.
