Eibach Pro-lift springs installed with pics and comments
Leftsidej
Missouri
Yes please!
Exact same numbers and specs for the 2019, even though it says 2017. For some reason, Eibach has issues with updating their catalog information (spring rate still list as 583, when that hasn't been the case for a couple years). Print this off and give it to your tech :p
https://eibach.com/us/c-145-product-releases-2017-ford-f-150-raptor-pro-lift-kit.html
TECHNICAL INFORMATION
FRONT:
OE rate: 93 N/mm (533 lbs/in)
PRO-LIFT-KIT rate: 102 N/mm (583 lbs/in)
Bump-stop: OE
Damper: OE
Tubing: N/A
OE hub center to fender: 608 mm
PRO-LIFT-KIT hub center to fender: 672 mm
OE Camber = -0.9 -0.7deg (+/-0.1 deg)
PRO-LIFT-KIT Camber = -0.4 deg
OE Toe = 0 - 0.2 deg (+/-0.10 deg)
PRO-LIFT-KIT Toe = 0.1 deg
Approximate installation time: 2.0 hr
GR8Ride
Upstate New York
Oh wow man thanks a lot!! Really appreciate it! Hope to be able to help you out sometime soon. I owe you one!
Leftsidej
Missouri
No problem at all! I've learned everything I know about this truck from other users on his forums, so it feels good having some knowledge to pass along!
Hope install goes well and put some pictures up when its all done :D!
0-60 freak
Why is nobody talking about geisers ...haha...here is my geisers, icons, 37s, I put some rubber caps over my ubolt threads95e9f5fe4f44b2ef9e76e0c69b9fd500.jpgec969bbdf68f87a9e6c82c72f488ef6c.jpg8c99d4ccc8650a657e263969bc4c626e.jpg3bc86744c980f13a6397406df7084248.jpg25314c9cb8d7a38a9f420737c62a19da.jpg524a7cfc70c105396dbe0f6031a1689f.jpg905b73cf70c5a82985e4d67b1ea97b51.jpg9f957d25e3b06f6e56b89d57a0c89f12.jpg
Sent from my SM-N950U using Tapatalk
vazo
Where did you get those rubber caps from?
Sent from my SM-G960W using Tapatalk
GR8Ride
Upstate New York
Yes will do!
Carlos M
Amazon...intended use are vaccume plugs
Are these installed where the rear blocks sit? I am getting my front Eibachs installed next Wednesday and if I end up nose high I am looking for a short term solution until I can get the Icons.
Carlos M
New rims with the Eibachs in the background.
The second photo is on my elevated driveway with around 200 pounds in the bed so I'm sitting nose high at the moment of this pic.
When you can, please share a photo on a level ground. I am about to do the same and curious about your results.
If you read this entire thread. You will see that everyone gets different results.
From Eibach, 2019 get 1.7 lift and 2018 2.25 once they settle.
Leftsidej
Missouri
Will do, after I had the Eibachs installed on my truck I posted some before and after shots that are pry on earlier pages in the thread. I have a 2017 and I can say with surety I only got around 1.8 inches of lift. Absolutely positive I did not get 2 inches. The consensus is that it differs on a truck by truck basis because of other variables, such as rear leaf age etc.
