Eibach Pro-lift springs installed with pics and comments
vazo
Absolutely! Where should I start my measurement from? Not sure what exactly is the norm in measuring for this
I think most measure in the center of the wheel to the bottom of the flare. If you could do all four wheels before that would be awesome.
Thanks
Sent from my SM-G960W using Tapatalk
GR8Ride
Upstate New York
Just got mine delivered today, I’ll post before and after pics when I finally get them installed.
Getting Eibach’s installed next week on a my ‘19. Are you going with the Canberra bolts? I’m on the fence whether I should order them.
I will also do measurements as vazo requested.
Johnkn
LaPlata, MD
FrodoTBaggins88
Looks great, are you running wheel spacers? Any comments/installation tips? I have the same truck and really like the '19 wheels, I'd just like to push mine out a little.
thanks!
FrodoTBaggins88
US - Utah
FrodoTBaggins88
thanks!
1.25" Faction Fab wheel spacers/adapters from Stage 3. They're identical to the Bora spacers/adapters. Would have gotten the Boras but weren't in stock at the time. Hub-centric and forged. You'd have to trim the studs about 1/4" in the rear but the front ones fit fine, no trimming needed. I put red loctite on the factory studs to bolt to the spacers/adapters and torqued to spec. Several hundred off-road miles and no issues.
galan.kelley
Looks great man! Can’t wait for mine to get here this week.
Did you use aftermarket UCA’s? Or just leave it stock?
