The heat exchanger for the intercooled turbos is lower than the grill and main radiator; clearly showing through the bumper cutout. Check it yourself, it's in a bad place for an offroad vehicled.
On the current 3.5 EB's on the regular f150's yes, but ford may have moved those in a different location for the Raptor if they were going to add the 3.5 EB into it, which could be a reason for masking the grille off. Just speculation, but hey could be a reason since what we can see through the mesh of the grille itself looks identical to the current grille.
The days of the modular powered F-150 are over. Motors built on the Romeo niche line are meant to be low production. If Ford was to put the GT500 motor in the Raptor it would a huge step backwards and the 6.2L is the top motor in the F-150 and what the Raptor was designed to have. The only reason the 5.4L went into the Raptor was because at some point in the R&D phase the 6.2L and Raptor got out of sync. The 6.2L was in development for over 10 year off and on it was designed to have a power steering pump if putting EPAS on was a simple process it would have been done durning the R&D process not 3 years into production.
Wow, can you fit both feet in your mouth or just one? You do know the meaning of a modular engine correct? The days of the modular powered f150 are not over, they've been here since 1997 and they're not going away. Ford is not going to go back to OHC and pushrods after all of this time with OHV and no pushrods.
And your comment with the 6.2 has been in development for 10 years, etc. is further reasoning towards it not being in this for the long haul in the trucks. It was supposed to be the next big thing, then things changed with the revamp and full new engine lineup. The 6.2 filled a spot as a premium engine since it was already in the works from long before the 3.7/3.5EB/5.0 lineup, and I'm ready to bet it's just a placeholder till the 5.8 is in full swing.
As for EPAS, again your comment the 6.2 has been in the works for a decade again provides an answer towards that. EPAS wasn't even a thought back then. EPAS is on the 3.7/3.5/5.0 because those 3 engines are 3 peas in a pod with their similarities, the 6.2 is the odd duckling and came through a different development path. If the 6.2 was done from the start side by side with the other 3 engines, very good odds EPAS would have been on that as well.
The reason is because the Lead engineer for Ford's V-8 program said there are no plans for a DI or DITT 5.0. I'm not saying that will never be a DI F-150 but it just won't be on this generation.
I agree with you on that one. I don't think DI will hit the 5.0 till a new generation of vehicles. If a next gen f150 and next gen mustang don't hit at the same time, I'd think the DI would hit the mustang power plant 1st with a mustang major redesign, as the 5.0 is the all-star engine for the mustang (with the exception of the shelby line), where the 5.0 is just a middle of the road engine for regular f150's.
BIG NEWS FOR THE 2013 FORD RAPTOR!!!!!
Since the 5.8 is so undeniably full of bad ass, Ford decided to......
Put over-sized tires and FOX quadruple internally by-pass shock on the GT500!!! I know what you're thinkin... Yes the new GTrapHUNDRED will only have 3 inches of suspension travel, but who needs travel when you got 650 fire breathing, 6.2 ass kickin, pony's under the hood??? This thing will row across the desert like a ancient greek god ship!!
Dude now we're talking! If that can tow 8,000 lbs sign me up LOL!
