scarrjack
stupid newb question. what are IWE's? for shame![]()
I believe it's "integrated wheel end"
Your front vacuum lines are probably cracked or broken causing the IWE's to only go in partially then popping back out.
Here's a thread that I wrote regarding the problem. As someone else said, there are several threads that talk about his. One of the most common f150 4x4 problems that exist. Cheap plastic vacuum lines that make the 4x4 work on these trucks.
http://www.fordraptorforum.com/f170/weak-vacuum-line-grinding-noise-fix-24281/
Hope this helps.
Mil T
Have them check the vac lines. I had them replaced on my 2010 and 2012.
If it's only grinding in 4 wheel drive it not due to cracked vacuum lines or loss of vacuum, the truck uses vacuum to disengage the hubs to be in 2 wheel drive.
And if the line is cracked it allows just enough vacuum to allow the actuator to rub against the hub causing the grinding noise and when trying to put it in 4 wheel drive will allow the gear on the actuator to slip and clunk as it's trying to get into 4 wheel drive.
I'm not understanding this..... The problem he is having is in 4 wheel drive NOT grinding in 2 wheel drive as if there were a vac leak like your thread is talking about, your thread states if you put it in 4 wheel drive the noise goes away correct? The truck releases vacuum to engage 4 wheel drive so if there was a broken line it wouldn't mater because there is no vacuum in 4 wheel. I'd put my money on a cracked iwe.
The outcome is a new t case has been ordered, another new set of iwes vacuum lines Solenoid and wheel bearing and cv axles.
Hopefully this solves the problems. A lot of help from ms mi raptor and a lemon law attorney did the trick
