I just wish that we had some definitive evidence that running in off-road mode actually did "de-sensitise" the airbag sensors to some extent, then I could sleep easier at night.
Due to legal reasons, you will never find an answer to the question of air bag sensitivity in any mode. In the same reason, you will never find the answer to how much weight on the passenger seat will turn the airbag on/off. If they tell you a number and some freak accident happens and the airbag should or shouldn't go off, then someone is liable. A blip from the Raptor Supplement from your owners guide states this:
During off-road mode the AdvanceTrac system provides the vehicle with
alternative AdvanceTrac calibrations, which improve off-road performance. Off road AdvanceTrac calibrations are enabled for 2H and 4H. When the AdvanceTrac button is pressed once AdvanceTrac Sport will engage. In this mode the vehicle will have ABS, traction control and yaw control settings specifically calibrated for off-road conditions.
The RCM (module that controls the airbags) uses the yaw and roll motions to determine severity of crashes/roll overs, etc (along with lots of other data). Since the calibrations are changed to 'specific to off road conditions', the data that is coming in from the sensors is the same however, the module allows for a higher threshold before intervening. Again, this is interpreted based on the information from the owners guide and therefore the information is only that... Use or ignore as you wish.
Understand that the air-bags are intended to keep your head/body from contacting surfaces that would hurt. In my opinion, the air bags are there for a damn good reason and like hell if I want to try to get close to reaching the threshold of deployment. My head has hit an airbag once already and although I am very thankful it was there, I do not want to experience that again.
Ford has performed extensive testing on the truck to avoid any accidental deployments, trust me.
I know @
PalmaVirtuti is just looking for piece of mind. How about this: The air bag is piece of mind. If it goes off, be glad that it did and not mad that it did. I bet
these guys are not mad that the bags deployed (along with post-crash alert horn and lights).
