Differential fluid change - do I need friction modifier?
Ruger
Northern Nevada
Received and thank you, Vash!
FRF Lady, will definitely keep FreedomMotorsports in mind.
Great support to the community!
pirate air
will plunder your booty
one more try
"Chatter" is a condition that Limited Slip Differentials (LSD) exhibit when the clutch pack creates a friction that takes more force to overcome than what falls within the design limits. The LSD limits slip between the two wheels by friction created by two sets of clutch packs (each axle shaft/wheel gets one pack). The clutch packs have a specified value of friction, or force that they should create for proper operation. That friction value is something that can/is tested fairly easily with the right tools. Too little friction, and the wheels will easily spin independently almost as if the differential is open (a one wheel wonder). Too much friction, and the wheels will resist turning independently which isn't a bad thing.. until you try to turn... This is where your "chatter" comes in. As the wheels try to spin at different speeds the clutches hooooooold then break free, then hoooooooold then break free, then hoooooooold then break free, and over and over and over. This all happens in seconds as you make your turn. The vibration it makes resonates up thru the chassis and into the cabin giving you the chatter noise and if you have a sensitive enough ass, you can feel the shock load thru the seat bottom.
Enter the friction modifier. The friction modifier, chemically modifies the resistance the clutch pack provides so that it holds just enough but still allows the wheels to turn independently during a turn without the hooooooold and break. For hard core off roading or drag racing, this style of differential pretty much sucks, but for your every day mom and pop driving, it suffices.
The amount of friction modifier you need depends; How worn are the clutches, how many frictions and steels make up a pack, how strong is the preload spring forcing these packs together, what kinda vehicle is this differential in and how is it used? I had three mustangs in my 20's and everyone of them had a LSD at one time that chattered. I did that on purpose. They never saw modifier, even when I rebuilt the LSD. Those clutches were going to hold tight, even under the smokiest horse whip'd burnouts. For customer vehicles that chattered it was different. I opted to rebuild most. Considering clutch material, clutch/steel quantity, spring strength and pre assembly secrets usually delivered a chatter free diff without bottle after bottle of modifier.
So, what does clutches and chatter and friction modifiers and mom and pop driving and one wheel wonders have to do with Raptors??? Nothing.. There is no LSD in the Raptor. The nearest clutch pack is in your transmission. Your rear differential is a mechanical locker. It uses tooth and groove to lock the wheels. That handy dandy pull out locker 4x4 switch sends voltage to a magnetic actuator which forces the tooth and groove hubs together, locking your axle shafts as one solid unit. No amount of friction modifier is going to help the voltage flow, the actuator to actuate or the tooth to groove.. Adding modifier is attempting to modify an element that doesn't exist.
I understand people seek the most concrete of concrete answers for what seems like such a confusing and conflicting question, but take it from someone that broke a LSD or two, rebuilt a LSD or two, built a mechanical diff or two, made a living doing this a time or two, went to school for a diff or two, messed with friction modifier a time or two, chased a nvh concern a time or two.. The answer isnt that complicated, the dead horse died back in practical land. This thread and the never ending quest for friction modifier reads about like this to me,
Are red zip ties required to help my friction blender fly faster to school bus island? Can we get some confirmation on that? I've heard a half salty owners manual with cracker crum bump stop thread additive will make so much black dragon chatter 3.0 horse power, my non lsd needing lsd fluid prerunner rear end will explode my thimble nimble spindles while sitting still at trr. This is serious shit, that needs serious answers, by serious people, people!!
155mm
i thought we already moved past the friction modifier and the outstanding question was why older raptor supplements called for 75w140 while the latest ones say 75w85?
Madcowranch
Madcowranch
Genetically Modified
OK
Now that is some funny chit right there!:happy175:
Nick@ApolloOffroad
Houston, TX
Pirate, that actually made me chuckle hahah
We've now moved from friction modifier to proper weight for the rear diff. Any insight on that?
Ruger
Northern Nevada
Okay, Pirate, you da expert. Clearly! Would you happen to know if the differentials on the 2010s and 2011s are the same as those on later models, and do you know why manuals for the earlier models specify 75W-140 and the later models 75W-85? I'm going to replace my diff cover at 50K miles and will need to know very shortly. Thanks for your bringing your expertise to bear on this!
---------- Post added at 09:15 AM ---------- Previous post was at 09:00 AM ----------
I have asked the question of our new Ford Representative here:
http://www.fordraptorforum.com/f6/greetings-fordservice-32464/index6.html#post647258
She has responded with a message that she has sent this up the line for what I hope is an authoritative answer.
Yukon Joe
Trafford, PA
I thought they changed the diffs in 2012 to gave one more tooth in the gear set? Isfast discussed it in a thread some where.
Yukon Joe
www.RUNRAPTORRUN.com
J DAMAGE
NJ
Ok, just got off the phone with SVT-Ford racing, @ 12:35 est 3/12/14, spoke to Isaac, ask him if Friction modifier is to be used on my 2011, the answer was yes, 4 oz, being the supplement states it, it is to be used, I also mentioned about e-lock, and he still said to use it. So what the hell, guess im using it, being its under warranty, if anything should happen, and they pull the oil sample bull, its in there.
Hope this helps.
Ruger
Northern Nevada
We'll see what Crystal the Ford Rep comes up with. I'd be real surprised if Issac turns out to be right about the friction modifier unless we get a simple "follow the manual for your year vehicle" response - that's all Isaac did.
J DAMAGE
NJ
Exactly, he read just as you or I would have, and is saying use it, being im doing my diff cover this weekend, I'm just going to add it.
We do need a definite answer, because the manual gives the oil weight front and rear, as well as the FM, but doesn't say to use it or not, unless they want you to use it being the manual has it printed/stated.
