Deep Sleep Mode Activated
termite352
Venice, Florida
Mine went into sleep mode twice while recovering from a broken right foot. No key required, just couldn’t start remotely. Plus it was unlocked in the garage so all I had to do was push the button.
Diesel71
Derry, NH
Thanks Maryland...correct on the key...you’ll need it to unlock the truck. If you have 802A, you’ll need to use the key that is inside the fob...just pull that out and unlock. Then use the start button to start.
Mine goes into deep sleep mode quite a bit as I travel for work. Never once used the key and I have 802A - I usually remote start it before hand with zero issues. Just my experience.
TXRaptor
TXRaptor
Yup, been reported before here and also findable on google.
Thanks, Smurf! Since I did not know it was a feature, I had no reason to search for it.... ;)
As for the replies on using a key, I did not have to use mine. My truck is an 802A and I locked the doors before I left. I walked up to the truck with the key fob in my pocket and when I grabbed the door handle, it unlocked and opened normally. I got in, pressed the start button with the key fob still in my pocket and it started right up. :cool:
TXRaptor
TXRaptor
I bought mine in May. It's in deep sleep mode more than it's not.
It sounds like you need to drive your truck more often! :D
I have less than 11,000 miles on mine in 18 months and this is the first time it has sat for more than 14 days in a row.
Swimmer
Olympia, WA
This just happened to me last week. My battery completely died to the point where I couldn’t jump it or charge it. I put a new battery in and everything works fine, except my FordPass app is still reporting that the truck is still in deep sleep mode. Is there a trick to turning that off?
TXRaptor
TXRaptor
... except my FordPass app is still reporting that the truck is still in deep sleep mode. Is there a trick to turning that off?
My notice went off automatically after I started it. You might have to take it in to a dealer to get them to reset it. I would say to try disconnecting the battery to reset the computer, but it sounds like you already did that when you replaced it!
singh3204
houston
but there is no key hole on the doors of the truck
jabroni619
You don't need the key in deep sleep unless your battery actually dies. Keyfob works just fine.
Swimmer
Olympia, WA
I disconnected the negative terminal and waited 5 minutes. That did the trick! Everything is back to normal.
