Deaver +3 review
Huck
Huck
Chicago Sw Burbs
Should be 1" over I will measure again to be exact
It's definitely higher than stock
oplersx
British Columbia
I just measured mine, stock spring, 660km... rear from ground to lip measures about 110~112cm, which is just about 44inch :hmmm2:
Huck
Huck
Chicago Sw Burbs
That's correct. Give your truck a couple hundred more miles and the rear should drop to about 43" yours are still brand new
oplersx
British Columbia
So that means I should get the deaver +3 instead of +2? Initially I am looking at the RPG stage 3, but now seems deaver spring + RPG bump stop is a better choice?
Huck
Huck
Chicago Sw Burbs
+2 is stock height. Just removes the spaced block. I can't comment on the deavers yet. Just installed them Friday. I can say that from day 1 I was never content with the nationals, sd's sacked out and as you can see the replacement hd's did as well. So far the deavers are great and perform amazingly. Much different design than national. Time will tell
oplersx
British Columbia
If you are at 44inch with +3, I think I will have to go with +3 too.. please double check when you could.
Bigg50
Benicia, CA
Glad to hear they're doing well for you. I have around 14,000 miles on mine of which approx 3500 are offroad (with 500lbs of gear) and 1500 towing a 6,000 travel trailer. Still perform great and no noticeable sag yet.
RAPTURR
San Antonio. Texas
I'm sitting at 29-1/2" center of hub to flare lip.
44-1/2" ground to flare lip.
That's with around 450 lbs in the bed.
That's with about 21000 miles on them.
It's also a 2013 Screw
Sorry for the late response
Fred Maconi
AKA RaptuRR / not that Fred
