MTF
So the stock bump stops are fine with +3 deavers
You will need a landing pad relocating bracket because you are removing the stock horns for the bump stops.
I forgot were I bought mine, been so long ago.
I think I got them here: https://www.rpgoffroad.com/product/air-bump-strike-plate/
Or check with them: https://sdhqoffroad.com/collections...-ford-raptor-rear-leaf-spring-replacement-kit
Now if your going to buy a bump stop kit then the relocating bump stop plate would also not be needed.
Needing the spacer like suggested would not be needed if your using a drop down shackle.
