Cylinder 8 misfire engine light
MTF
Celebration, Florida
Just so there's no misunderstanding, you two different Tunes or one?
One for no cats (O2s off) and one for cats (O2s on)
Hi-Flow cats with a Tune with O2s on usually require rear O2s spacers.
Running cats with the rear O2s off could pose an issue, maybe.
Never heard anyone doing that.
I'm sure you discussed all that with JDM.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
I have high flow aftermarket cats so they leave rear 02 turned off. So that same tune will work for the straight Y. I just called JDM and they said it shouldn't be an issue.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
Hey I'm taking cats out now. I noticed my exhaust clamps were super loose like hand tight. Maybe that could cause 02 miss reading because of vibration?
---------- Post added at 04:31 PM ---------- Previous post was at 04:30 PM ----------
Passenger rear 02
---------- Post added at 04:59 PM ---------- Previous post was at 04:31 PM ----------
Driver side rear 02
Passenger side cat internal
---------- Post added at 05:27 PM ---------- Previous post was at 04:59 PM ----------
Passenger front 02
Driver front 02
MTF
Everything looks ok. Well at least you know the cats are the honeycomb type.
Were you able to switch the two fronts?
---------- Post added at 08:47 PM ---------- Previous post was at 08:45 PM ----------
You have to be careful with those wires, they are very small and easy to brake.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
Yeah they got kinda twisted up when loosening them. No I didn't switch them. I'm putting in the straight pipe right now tho
