- Joined
- Jul 2, 2013
- Posts
- 879
- Reaction score
- 1,115
Can you elaborate on the "nobody has parts for the 6.2L" for us please? I'm pretty sure we were all under the same impression, and that impression was the availability of parts from Livernois. They are not making a 6.6L motor without some parts... I don't know if they are doing it through bore and stroke or one over the other, but they're/you're not getting more displacement with the same parts as a 6.2L. So what gives?
Also, for the hefty investment you've already made, why aren't you doing a completely custom fuel setup? The fact that most people don't "support" the BAP at all and all push for a larger pump... what is the reasoning? I don't understand how the BAP with the stock pump is any more or less than the fuel rails can handle vs a pump of equal value to the stock pump @ 14-16V. I've never had a BAP failure, but I've also only used them on low dollar budget builds where the BAP was already available and the labor to remove the tank and modify the fuel hat was more work than it was worth.
Thank you for treading these waters, we all greatly appreciate it.
Jack, I'm taking the liberty to post this link to the " Group buy " post on oil gears. The vendor stated " in stock ready to deliver" that was on 2/19. A FRF member immediately ordered same day (2/19) here we are on 3/18. Still no delivery!
It's pathetic. At least I know better.
http://www.fordraptorforum.com/f5/l...aptor-fuel-pump-upgrade-kit-31833/#post652120
