Hey FordTech, what’s a good lubricant to use on the moonroof?
Krytox grease.
Anyplace you recommend to get it for less than $300/tube?Krytox grease.
this. it's what i bought also
the 0.5 oz tube is all you need. $22
my point is that something made in the 90s by toyota is of higher quality than these panos. the fact that you have to lube these things in the first place is ridiculous. my last six vehicles have had a moonroof or pano of some sort, none of which had issues or needed maintenance within a year of ownership except for the ford.Never experienced that on any of of the multiple recent Ford vehicles I've had with panoramic roofs, never mind ones that were properly lubricated. "Lexus" (overpriced rebadged toyota with a made up name) never had a panoramic roof opening 30 years ago, nor does Toyota offer one on their current trucks, so your reference is irrelevant.
Your point is invalid and absolutely baseless. The panoramic glass roofs on these trucks are massive and heavy; you can’t compare it with the sunroof on a car. If you don’t use the system frequently and the seals stick, something has to give. In this case it’s the brackets, which is a better alternative than cracking the glass panel.my point is that something made in the 90s by toyota is of higher quality than these panos. the fact that you have to lube these things in the first place is ridiculous. my last six vehicles have had a moonroof or pano of some sort, none of which had issues or needed maintenance within a year of ownership except for the ford.
