Cam Phaser/Engine Failure Reports
Status
Not open for further replies.
MnFlyer
MN
normally...i garage park, so i do here sounds because it is so close to the wall and that tends to make it sound loud.
This is over Christmas parking outside and a 30 degree start up. Oil is fresh, less then 2k miles and at proper level.
Just to pile on.
My ‘19 sounds like that almost exactly.
We spent Christmas in ND this year and my truck sat outside in -10 C* temps. Sounded just like yours on startup.
Kuan
Syracuse
"This is something that will get louder with time and then it gets to the point of failure."
FALSE
"Be advised that the people with parts post-April still have the same issue. Even with the various part number changes"
What are these part numbers?
"The Q4 TSB with the yet-again revised parts never happened."
Who said there was going to be a Q4 TSB? Ford or some dealership with no facts to back it up?
Here is the information regarding the TSB that should have come in Q4 2019:
https://www.fordraptorforum.com/threads/timing-phaser-tsb-coming.70706/
Special service message # 48168 regarding "ticking/tapping or rattle type noise on start up after a cold soak" says possibly due to worn variable cam timing units, and then to replace all 4 of them - specifically states do not replace timing chain, tensioners, guides etc. unless inspection "clearly identifies a concern". SSM also states TSB will be published 4th quarter 2019.
Cam phaser part number changes... Are you living under a rock? The gen 1 engine ecoboost had several different part numbers for the cam phasers. That same concept morphed into the gen 2 engine ecoboost. Again, they have changed numbers for the phasers at least twice now, and Ford said a third new number would be released Q4 2019. I am kind of surprised that you actually have no idea about any of this. You might want to go do some research a bit more before you com here guns ablazin.
Donmatteo
Santa Clarita / Coronado
How absolute is the naive....
Where, in that thread, does it specifically QUOTE FORD, link, doc, screen shot, smoke signal FROM FORD that a SPECIFIC Q4, 2019 TSB? is coming.
All I see is someone relaying information from a 3rd party about a possible tsb. NOTHING in that thread about a Q4 TSB is fact.
Also, Gen 1 wasn't an eco boost. It was NA V8.....Are you living under a rock?
And, again...WHAT IS THE SOURCE FOR THIS? "Ford said a third new number would be released Q4 2019."
By my records, the 2nd set of parts was released in April of 2019. Nothing since then.
YOU might want to do some research a bit before you relay hearsay and conjecture.
Kuan
Syracuse
Your bud Fordtechone acknowledged it too. Problem is, it never came out and nobody knows what the hold up is.
Donmatteo - you are really not that knowledgeable on any of this. We all know there was a Gen1 raptor and now a Gen2 raptor. Gen1 had the 5.4, then went 6.2. Gen 2 has the 3.5 ecoboost. Now, with regard to the 3.5 ecoboost, there are two generations... technically 3 if you think the HO is gen. The gen 1 ecoboost was 2010 - 2014. The gen 2 ecoboost is 2015 - present. Wow man - do your homewaork - you sound like an idiot.
Donmatteo
Again...is this phantom TSB referenced is actually noted, or on verifiable documentation? Until then, it's speculation and rumor.
As for the Gen1 debate...I quoted you saying that the Gen1 was a ecoboost. Ecoboost means TURBO. What GEN 1 was a turbo?
Gen 1 (2010-2014) had a 5.4L V8 and a 6.2L V8 - NO ECO BOOST
Gen 2 (2017 - ) has a 3.5L EcoBoost (twin turbo)
What Gen1 2010-2014 had a turbo???
https://www.ford.com/powertrains/ecoboost/?searchid=1293550695|54825601618|492503483472|seg-hybb-181002&ef_id=EAIaIQobChMIvvzF1ofo5gIVmMVkCh2iZwPSEAAYASAAEgJn4_D_BwE:G:s&s_kwcid=AL!2519!3!270967164921!b!!g!!+ecoboost
EcoBoost engines combine three technologies—turbocharging, direct fuel injection and twin independent variable camshaft timing (Ti-VCT)—for power and efficiency.
"Wow man - do your homewaork - you sound like an idiot." Exactly
MnFlyer
MN
There are 2 generations of the 3.5 ecoboost. Gen1 had direct injection only and smaller turbos I believe.
Gen2 has port and direct injection and slightly bigger turbos. I think the timing chain is slightly different between the 2 as well.
Donmatteo
I know. Kuan said this...."The gen 1 ecoboost was 2010 - 2014. The gen 2 ecoboost is 2015 - present. Wow man - do your homewaork - you sound like an idiot."
What Gen 1, 2010-2014, was a ecoboost?
Kuan
Syracuse
Oh man - you are completely screwed upo_O
There are Gen 1 and Gen 2 of the Raptor.
There are Gen 1 and Gen 2 of the ecoboost engine.
I never said there was an ecoboost Gen 1 Raptor.
I can see now that reading and understanding is not your strong suite.... so that explains your blindness to other things.
Donmatteo
You're right. I was skimming your posts. I see now you were referring to the gen of ecoboost and not the raptor.
You still have not provided evidence, from ford, of this Q4 TSB.
Status
