Cam Phaser/ Engine Failure Poll
Have you had or have a cam phaser or engine failure on your Gen 2?
  • Total voters
    629
Fender
I made an appointment, theyre gonna keep it overnight to hear it in the am. Will see!
2019 scott
Pa
I have a 5/19 build date truck with only 4200 miles on it. I don’t know if it will prevent the issue from coming or not but i religiously hold the gas pedal to the floor and build oil pressure every time i cold start.
Donmatteo
Santa Clarita / Coronado
They had the new parts in the build by then. It was April of 19. If you get it, it's because that part is bad one of a bunch.
2019 scott
Pa
Yes i hope so but i have been reading of a few 19’s that have the problem and with the way my luck goes i will be one of the unlucky few.
2019 scott
Pa
Hear you on that. I have a 4/19 built.
I just figure building oil pressure on cold starts really shouldn’t hurt anything and maybe it will prevent issues down the road. It might shorten the starter or battery life slightly but those are cheap and easily replaced. The vehicle should have a pretty heavy duty starter in it since it has auto stop/ start.
Donmatteo
Come to think of it. I don’t recall exactly what the issue was with the cam phaser other than the suppler to ford being the source of the bad phaser. I don’t know if it was a design issue, or a suppler manufacturing issue. @FordTechOne, was the cause of the issue discussed before?
FordTechOne
Detroit
i have a 10/2018 build, just started around 36k miles, faint rattle on cold startup for 2-3 secs.
It doesnt really bother me a lot, but im wondering if i should take it in
A cam phaser issue is not a faint rattle. It's a very distinct, metallic rattle that is audible from a distance away when using remote start.
The problem with threads like this is that everyone starts to over analyze their vehicles looking for noises which in many cases are just normal cold start engine operation.
