Cam Phaser after oil change. Coincidence?
MrSkunks
Miami
Had my local dealer do standard oil change. Got the car back, all seemed normal.
Next morning, crank it, I thought a cat or something snuck in the engine. Happens again, sounds like cam phaser. Now it’s every cold start. What are the chances this happens after the oil change?
I have fords extended warranty, any issue getting this covered under that?
julien194b
offroad addict
Europe FR.
I guess you have checked oil stick level ?
Only the mecanic who have done the job can tell...but of course , he will say everything was fine, (what could be true) so now, you can't really know why, you search how to fix. Good luck
isis
PA
I can’t logically connect the two. But that sucks. Mine was covered under the warranty at around 50k miles no question.
turboturbo
muskoka
id says the chances are pretty good of it happening after a oil change. id say this because going the other direction.. mine had a slight rattle here and there went back to ford branded oil and its quiet again. dunno but there's something to it.
