Bypass rack - 3.5s or 4.0s???
Jordan@Apollo-Optics
aka <b><font color='darkorange'>LSUstang05</font><
On 4.0's I think some people had issues with specific tires rubbing the bypass tubes. Run wheel spacers or get a different wheels with more negative offset to push the wheel a little further out to make sure the tire doesn't rub.
RLTW
TX
@RLTW how do the 4.0 fit? I was thinking of going that route but ended up deciding to go with 3.5
They fit just barely lol, gotta test lower shock mount location a bit before locking it in.
SVT_Aaron
El Paso/Ft Bliss, Texas
Damn lol I want to see how that turns out, the 4.0 are sick but I was concerned this happening and rubbing
RLTW
TX
Yeah, definitely have to be precise, at full droop the shock body is not far from the svc bypass rack, and then you need to center properly between where the tire is and where the spring would be at full bump.
SVT_Aaron
Jeff talked me into going with the 3.5 so that's what I ended up doing. Also for the reason that you stated above but glad you were able to make it work[emoji1417]
RLTW
TX
They marketed the kit as being able to accept 4.5s when it was released but I don't see how that would be possible.
