nikhsub1
Well, rotors aren't warrantied anyway for the most part, they are a wear item. But it would have no effect on the ABS system etc in terms of warranty.Does this VOID your brake warranty?
Unless R1 has changed their process, or attention to detail, I’d steer clear. I had their drilled and slotted rotors on my previous Jeep SRT about 5 years ago and the inset area of the drill and slot where the pad doesn’t contact the surface rusted terrible in no time. Replaced with Brembo and never had an issue, so it was def R1’s quality.
Just installed R1 brake kits on two of a friend’s cars.
His front rotors were coated but not the rears for some reason in both kits as well as the replacement rubber hardware was low quality and too firm and nearly all of them were impossible to replace because of it. I would never buy an R1 kit again.
I have run Powerstop kits in the past and have never had any install issues and they always work better than stock.
Rubber hardware, can you elaborate?
The rubber bushes that go through the caliper which the caliper slides on.
The Alcon kit will work with 17's tooDoes anyone know how many 4-6 piston brake upgrade kits on the market will work with 17” rims. I like that the R1 kit will work but would like to compare other kits if there are any. Thanks for the 25% off freedom motorsports.
We have sold over a thousand R1 brake kits on FRF and FB since 2012 with rave reviews. For an OEM priced replacement, these are the best out there for our trucks. For the month of April we are offering 25% off, use promo code: FRF202025
https://www.freedommotorsports.us/c...m-replacement-performance-brake-packages.html
You will be happy you got them.
Nice kit. I purchased Ceramic brake pads once for my F150 and I loved them as they were really quiet, great stopping power and no dust, however, they ate through the rotors really fast.
Do the rotors in this kit hold up to life of the ceramic brake pads?
