Brake Bleed
Monte87
NY ******
Brake maintenance mode is required to service the rear brakes. Per the Workshop Manual, a scan tool capable of performing the pressure bleeding procedure is required to bleed the system.
"a scan tool capable of performing the pressure bleeding procedure is required to bleed the system."
What do you mean?? a scan tool is needed to bleed brakes?
Thanks Anthony
FordTechOne
Detroit
Thanks Anthony
Yes, because Gen 3s are equipped with an Electric Brake Booster (EBB).
Monte87
NY ******
Is it possible to just put truck in "brake maintenance mode" by following those certain steps w brake pedal, ignition switch and pull and or push E-brake button to put and remove truck from maintenance mode instead of having a scan tool?
Thanks Ant
FordTechOne
Detroit
Thanks Ant
Yep, and those steps should be in the Owner’s Manual.
360North
Georgia
@FordTechOne …can we replace our rotors & pads without needing to bleed the brakes, or is it required the same as if we upgraded to braided lines? The reason for the question, is that if we upgrade our rotors & pads but dealership won’t install them…doesn’t that sort of put the aftermarket out-of-business or force the aftermarket shops to have FDRS for installs?? Not to mention, no more DIY replacements at home.
FordTechOne
Detroit
Yes, pads and rotors only require maintenance mode.
Bleeding the system, such as after caliper or brake line/hose replacement requires a scan tool to do the bleed procedure.
Members online
96,364
60,273
NTXRaptor
Latest posts
