Blow off valve on Gen 3
Juanitobunito
Chitown
MrBuddha
NorCal
I just tried to install a boomba adapter and it pushes the pressure release plug back enough that it hits the charge pipe. I'm unable to get the pipe back onto the intercooler.
Anyone else been able to successfully install the boomba on a gen 3?
jAKe47
Georgia
You should be able to use the other set of holes and that will angle the BOV slightly upwards to be able to clear the charge pipe....
That's not my pic, I pulled it off of Google images. I had to do this exact thing because I broke off one of the screws in the housing like a moron. It ended up working out though. I did have to pull the entire intercooler to be able to get to it better.
***this was on a gen 2 but gen 3 should be the same***
Warpath
Springfield
I have it installed on my Gen 3, Jake is correct you use the other set of holes.
23Raptor37PP
texas
I just installed a Turbosmart Vee Port EM on my gen3 this weekend. Easy install, makes noise as intended. No cel’s to report thus far.
I did the same and lost performance with cel under hard acceleration. I added the cvf titan 2 intercooler. Any idea why id get the cel and loss of performance?
SeasickLI
Long Island
Only things I could think of is:
-Boost Leak
-BoV wire not connected
-BoV piston stuck open
Miami, FL
I installed it quite some time ago along with the Garret FMIC and I haven't had any issues. The blow off is only audible under heavy throttle / 6+ PSI for me.
