Blindspot and cross traffic detection error new raptor
J
jsimon77
Los Angeles, Ca
I’m in the same boat now. Blind spot and cross traffic errors after install of PPF. They did break one of my mirror motors which they replaced and I guess the system has to relearn once you disconnect which they did for the install since they take off lights and mirrors. He said to drive it for 50-100 miles and it should reset after he consulted a Ford Tech. It did go away one drive home from work (~18miles) the other day but it typically faults right away when I start driving. It’s been a week since the install. I’m hoping time or maybe a longer drive would fix it but also don’t want to aimlessly add miles and burn fuel in the process. Anything would be helpful regarding specific milestones. I.e. one drive, multiple drives, time/distance, traffic conditions.
Thanks
I had no such luck...I had to take it to the dealer for repair.
raisins
NJ
So for educational purposes, what is the correct process to unplug harnesses?
Brent M
Tucson
For what it’s worth I recently hit my right side mirror on the side of the garage which oddly did not break the glass but did break the tabs on the motor- dealer wanted 2k to replace the whole assembly. Ended up just buying and replacing the motor for $70. However once reassembled I was getting blis and cross traffic faults. For the past three days. This morning I was checking to make sure all the wires were connected, started the truck and whalah not more faults. I guess the drive it around for a bit and it will reset works…
