How does your carlinkit 3.0 work? You like it? Do you have a link to the one you ordered?
Good looking Rap.
No A Pillar lights? C’mon...
What about a whinch? Only problem is then you need a front mounted IC which means no S8 light.After a long wait and a lot of tire-kicking, I've finally got the keys to my own 2020 Ford Raptor.
Starting my build thread here as thanks to FRF, I've got quite a few parts on the way and we're going to get the truck completely dialed in rather quickly.
I don't really %&* around on these types of builds and want to get it completely set up the way I want as soon as possible so expect quite a few updates incoming.
2020 Ford Raptor
38k Miles with Ford Extended Warranty - Paid $70k before T&L for those interested (12/21)
Rapid Red Metallic on Black
802A
Carbon Fiber
Moonroof
Tailgate Step
Previous builds:
-Porsche C4S
-Porsche GT3
-Audi R8
-Old Tow Rig: Nissan Titan
Primary Uses:
-Daily Driver
-Backcountry Hauler (Camping, Mountain Biking, Snow)
-Race Tow Rig (24' Aluminum Featherlight)
-Road Tripper
Incoming Parts List:
Engine:
Power Commander (will remove when Cobb Tuned)
Roush Cold Air Intake
Roush Catback Exhaust
CVF Titan Intercooler + Pipes
AMS Inlet Tubes
Cobb Accessport +TCM
Mishimoto Trans Bypass
Mishimoto Trans Cooler
Mishimoto Oil Can
Mishimoto Radiator
Mishimoto Expansion Tank
Wheels/Tires:
New K02s (12/21 at 38k miles)
Enkei RPT1 Wheels
Alcon 6-pot Front Calipers and Slotted Rotors
Alcon Rear Slotted Rotors
Stainless Brake Lines
Castrol SRF
Suspension:
Eibach Front Springs
Deaver +3HD Leafs
SVC Bump Stops w/Fox
Truck Bed:
RSI Smartcap
BuiltRight Bed Goods
Shovel, Jack, etc
Lights:
Morimoto Headlights
Baja Designs Sportsmen Fogs
Baja Designs S8 Center Grill
Baja Designs X6 Lower Grill
Baja Designs S2 Reverse Lights
Baja Designs Sport A-Pillars
LED License Plate Lights
Interior:
67 Designs Arm/Mounts on BuiltRight Base
Carlinkit 3.0 Wireless Carplay
Rear Underseat Tray
Dash Cam of some sort
Appreciate everyone's experience and guidance as I work through this, there are almost too many parts available for this truck. If I missed something or if there's something you'd recommend, fire away!
My buddy recommended it to me and it works pretty well. Here’s the linkHow does your carlinkit 3.0 work? You like it? Do you have a link to the one you ordered?
Morimoto XB Headlights Installed. These are friggin awesome.
Install was pretty simple with one miss, hardwiring the DRLs. The provided kit had the wrong fusebox wire (2020 problems) so I used a relay spliced and soldered into the passenger corner marker (blue wire) as the switch.
Highlights:
-4x projectors. The new model is Bi-LED which is why you see all 4 turned on in the photos. That's the low beams, not highs. Much better beam pattern and spread, it's insanely better than stock. And yes, I do use all of these lights lol.
-Sequential or standard turn signal
-Super bright DRL (I chose amber but you can also get white I think)
Big thanks to @4x4TruckLEDs.com! I'm super happy with these.
I ordered the Morimotos from @4x4TruckLEDs.com - Shipped quickly and got here fast.Price and level of difficulty for the DRLs? Also, any before or after night photos?
