Has anyone seen or heard a manufacturer working toward a big brake kit? I’m assuming the front is the same for the gen3/r but the rear is different?
No way that will fit under the factory wheels.Rotora has a BBK. Just came out recently.
This looks like it’s a good option. Anyone have any experience with this kit?
Wilwood Disc Brakes - Search Wilwood Brake Kits
Wilwood bolt-on big brake (bbk) conversion kits are designed to provide superior braking performance and a highly detailed appearance over a wide range of domestic and import applications. Ssearch for Search Wilwood Brake Kitswww.wilwood.com
I had the R1 kit front and rear on my Gen 2 and it was amazing. I just can’t see myself keeping stock brakes on the R, too much truck for the stock stoppers.
The Willwood kit is for 17” which is perfect.I didn’t see wheel size requirement, I’m guessing 20”. If Alcon comes with a kit, hopefully theirs will work with 18” wheels, that’s what I plan on running.
Something that these brake kit manufacturers may not be aware of is that Gen 3s can set DTCs when larger calipers are installed. The Electric Brake Booster doesn’t like the addition fluid volume that is required to apply the pistons, so it thinks there is air trapped in the system. It’s been an issue with the Shelby upfitted trucks with the 6 piston calipers, and I’m not aware of a fix.
