Best Intercooler for Stock Location?
CigarPundit
I like wood
Georgia
Other than the price difference, do people like the CVF better than the Whipple? I was planning to get the Whipple with a JDM tune. It has a bit more volume than the CVF and Whipple is generally good stuff.
Donovan
DC
All installed!
Just the normal ticking now associated with the intercooler change..that I have to live with lol.
Kirby Lastinger
Lakeland, FL
What ticking with the intercooler change?
I have heard of ticking if you change the BOV with the intercooler, but not with just the intercooler itself.
Donovan
DC
I have the turbosmart BOV installed. So yeah, ticking. Its not super annoying because of the glorious noise that is produced from the exhaust.
MattACK
Georgia
I totally agree with your point, it is not only about the air charge temperature, in fluid mechanics; there is something called turbulent flow and laminar flow. When the air is charged into any internal combustion engine it should be turbulent. That turbulent air flow will increase the momentum which creates better heat and and power through the engine. The bigger inter-cooler means less turbulent flow and less power especially in low RPM. That is why we get turbo lag at low RPM with bigger intercooler because there is no turbulent air charge flow.
It is a Raptor, we need the power in the lower RPM to climb the dunes and pick the power as soon as possible.
If we are talking about racing turbo cars then bigger intercooler may work.
You only want turbulent flow in an intake runner of a port injection vehicle in order to better mix the air and fuel as it enters the cylinder. This isn’t an issue on a direct injection engine since the fuel is injected directly into the cylinder under high pressure. Laminar flow is desired in all other sections of the charge or intake piping.
Turbulent flow will actually cause all sorts of problems and with fluid transfer (air or liquid), and laminar flow is desired. During heat transfer, turbulent flow is desired which is why the fins exist in the intercooler designs.
You potentially may have issues with a massively oversized intercooler which results in increased turbo lag due to the extra volume, small displacement engine, and/or oversized turbo.
96,586
60,555
CleverGirl77
