mprice1234
SVT Gen 1 Rules
Hard to find most parts for Gen 1's now days, searching salvage yards for wrecked Raptors is one option if dealer no longer has availability.
I simply purchased the replacement pad - which didn't come with the nut to attach it to the bumper. The easier thing to do would be to remove the bumper to add the pad, but I ended up adding it without taking the bumper off. Pretty straightforward to fix. I would do the fuse 27 sooner rather than later as when the fuse melts, it usually takes the fuse socket with it. Honestly doing fuse 27 is easy.This response is now several years old because I just purchased a twin to your car that happens to have had damage to the passenger side bumper guard. Right now it is held in place with a screw into that plastic base beneath it. I was wondering if you ever had yours fixed and how you get it done I will eventually replace my front bumper because when I purchased it, it had a small band in it, which I assume was how the bumper pad got loosened
Mine also did not have the fuse 27 modification and I guess I’ll do it myself but for now I just have a bag of 20 amp fuses just in case
