Baofeng or ETekCity UV-5R programming instructions
NickPic83
Rockland County NY
all the links work again @Slacker . THANK YOU. it took me a couple tries but i got it!
i did get this error message after it finished but i seem to have all the channels so i think im good....?
NickPic83
Rockland County NY
tried upload again and got the same message. im thinking im good. all the channels are there.
---------- Post added at 08:02 PM ---------- Previous post was at 08:00 PM ----------
here is the radio i got. i think it has a different antenna connection than the older models. anyone get a better antenna for it yet, if so which one? any benefit to a bigger antenna?
SVT_Mayo
Lincoln, RI
Anyone with OSX 10.9 have the correct driver? Have the cable that amazon recommended and have installed about 5 different drivers and still nothing. When I plug the radio in the mic light lights up red but radio does not show up in disk utility. Also chirp is installed and runs fine.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
I have this cable and used the drivers on the Prolific website. (http://www.prolific.com.tw/US/supportindex.aspx?id=7 Can't seem to hyperlink.)
Use "guest" as the account and password. The driver I used was: md_PL2303_MacOSX-10.6up_v1.5.1.zip.
Seems to have worked although "settings were not uploaded due to different firmware to IMG file" or something as above.
Jag
Cypress, TX
"Initial Frequency Load Baofeng UV-5R.img" off the Dropbox link is not in a recognized file format. Is there another list that can be downloaded?
Slacker
Slacker
Alexandria, VA
Download the file, open the programming software, then open the file from it. That is the right file.
treypal
Lord of the Raptors
Riviera TX
Newer firmware on the radio than the chirp file. Gotta keep the freq file current with firmware or you could have TX issues.
