All The Way
Mine had to be pressed in
Got any pictures?Are you guys sure K500193 is the correct part number? I ordered two from Rock Auto, pulled the stock BJ out and the MOOG joint slides right up into the arm and there's a little wiggle room in there. It should fit tight and have to be pressed back in. Definitely not the case with the MOOG joints I received. The boxes they were in both have K500193 on them too.
I checked the Moog site and they list this number specifically for the Raptor. The other F150s are a different part number, K500008.Are you guys sure K500193 is the correct part number?
From the pic on Moog's site, they are not splined.I checked 2 sites and this is the correct part number. Is the part number stamped on the bottom of the ball joints? They should have to be pressed in. Are the sides splined like these AC Delco ones?
+1If they don't fit snugly, I would give Moog a call 888-406-2330
Been there done that one. That's actually was my first idea of the noise but I knew I had already replaced the aluminum ones to the Chrome moly ones. I checked all the bolts that the upper mount uses but they were all tight.
I'm going to pull the entire front suspension on both sides off and inspect it with a fine tooth comb. I don't think it is the sudden drop return of the shock after a small bump clunk that is typical of the 3.0 shocks. I know what that sounds like.
Thanks again for the ideas.
