BakFlip Install Questions
Truck Wolf
Banned
in legal Marijuanaville!
Love my Bakflip F1. Best addition to my truck so far. Got mine from Autoanything.com and they were great to deal with (be sure to ask for their "absolute lowest price").
Kraka
Michigan
Damn, I cut myself because those things are so SHARP!!!! Ok, sold. I am going with the F1 for sure. Thanx for the pics, that really helped.
bfr
Mountain West
F1 for me too.
Talked with Bak about some of my questions (deleted by their moderator on their forums). So basically the HD and F1 are the same strength: 300-400 lbs of evenly distributed load. However they are very hesitant about recommending that you place much of anything on the cover unless it is in the open position (stacked 3 layers on top of each other) behind the cab. F1 is much better at scratch and dent prevention.
The Ford OEM accessory's primary difference is it uses better seals. It will be more water tight out of the box. It is built off from the HD model so no fiberglasss resin polymer or whatever it is called as on the F1. Latches and other hardware are all pretty much identical.
My thought is get the F1. If not happy with the seals...there is a wide variety of weatherstripping available that can be substituted.
bfr
Mountain West
Read a post from a guy who said given about 15 seconds and a coat hanger or other wire he can be into the BakFlip covers. Just a matter of flexing the rear bar enough to slide a wire in and pull the release. Sounds simple enough. Thankfully crime is not a big problem here.
bfr
Mountain West
If security was more of a concern, I'd probably be looking at something like the DiamondBack.
Not sure if they make a 5 1/2 footer but you get the idea. 3/8" dead bolts under the bed rail oughta keep things a little safer.
bfr
Mountain West
Truckwolf...you da man!!!
Actual BakFlip F1 drop shipped from BAK Industries delivered for $807.40. May be today only, 15% off their regular price...order until 11PM on Mar. 2nd. Must call them on the phone for the price. Mines on the way on or about Mar. 14.
