Baja Designs - NEW Laser Lighting! Ultimate Long Range Lighting
jikjak
Canada
[/COLOR]
The XL Laser Light will draw less than the XL80. We don't have specifics, but you can easily re-use your existing wiring.
www.bajadesigns.com[/QUOTE]
Hopefully a pair of lasers will draw under 10A. Im saving Aux 4 (my last free switch) for them!
Loufish
Burbank CA
Ok...Ok...enough!....Which line do I have to stand in to get a set of XL80 Laser lights?
AND...if I replace my XL80 LED's then I'll need to install a 30" S8 light bar to get all my other then long range lighting...
Baja Designs
Baja Designs
[/COLOR]
My guess is that they will draw between 3-5A each. I'll post up more specifics when I have the info available.
-Bailey, Baja Designs
www.bajadesigns.com
Baja Designs
Baja Designs
Baja Designs - Laser Lighting - UPDATE
We wanted to provide an update on the BD Laser Lighting. Unfortunately the ETA has been pushed towards late summer. There is currently one supplier for the laser chips we NEED and they have very limited quantities. In order to give you the best performing product possible we are using this one specific laser chip. We are waiting on the quantities we need in order to push a full production run of lights.
Our apologies for the delays. As soon as an update comes through I'll be posting up!
https://www.bajadesigns.com/products/Laser-Lighting.asp
-Baja Designs
www.bajadesigns.com
zombiekiller
OG BooBooRunner
New Orleans
-Baja Designs
www.bajadesigns.com
I'm holding all of the laser chips hostage until you agree to send me a pre-release pair of XL80 laser lights to field test.
Once I have received my field tester units, I will release all of you precious laser chips.
:chewie:
Baja Designs
Baja Designs
:chewie:
