Baja Designs - NEW Laser Lighting! Ultimate Long Range Lighting
Loufish
Burbank CA
So I have a pair of XL80 lights that I'm going to mount very soon on some "A" pillar mounts...these now pull about 80 watts each, what do you expect the LAZER replacements to use?
What I'm really saying is do I have to change the wiring if I replace the LED model with your LAZER model...
Baja Designs
Baja Designs
Will there be a squadron pro laser light or only XL and ONX?
A squadron laser light isn't planned at this time. If something changes we will certainly post up :biggrin:
---------- Post added at 07:15 AM ---------- Previous post was at 07:14 AM ----------
The XL Laser Light will draw less than the XL80. We don't have specifics, but you can easily re-use your existing wiring.
www.bajadesigns.com
jikjak
Canada
Now that overland expo west is done, is there any new intel on the lasers? (XL80 in particular)
Baja Designs
Baja Designs
No plans for an XL80 Laser Light, but we are working on the XL Laser Light (all laser chips). The XL80 is all LED where this would be all Laser chips. It's something our engineering department is working very hard on to make sure is perfect.
- Baja Designs
www.bajadesigns.com
jikjak
Canada
- Baja Designs
www.bajadesigns.com
awesome, cant wait to see them. any sort of eta?
so, to clarify, the XL Laser would be a cube light that could be hood mounted?
Baja Designs
Baja Designs
Hoping to have an updated ETA next week. It will look just like our other XL Series Lights, but have Laser Chips instead of LEDs. Here is an idea of what it will look like. You can easily mount these on hood mounts / ditch light brackets
*Actual item may vary
jikjak
Canada
awesome, now ive got a place to mount the lasers, please keep us posted!
do you think it will cause a lot of glare off the hood when mounted up there?
Baja Designs
Baja Designs
The glare will be very minimal due to the tightness of the beam and extreme distance. You'd have much more glare with a set of XL80s up there.
- Bailey, Baja Designs
www.bajadesigns.com
