Baja Designs issue
KentSD
www.BookBaja.com Baja yacht Support
San Diego
Ive always ran Rigid lights since light bars came out.
Switched to Baja Designs on this new truck (Just because they were a local San Diego company faster customer service if needed i guess)
My rigid use to run perfect never run through fuses.
My BD light is cooking 20 amp fuses daily and its driving me nuts
Anyone have this issue or figure out a solution?
I cant put a bigger fuse otherwise ill need to rewire the entire damn thing.
jabroni619
Relay harness would work for you and can even be connected to the 5a switches. You'll need to run the relay wiring harness but that should be a lot easier than rewiring the OEM lines.
zombiekiller
OG BooBooRunner
New Orleans
if the draw is more than 70% of the circuit and you're also using wiring that is too thin for the draw, you'll keep popping fuses. It could also be a short, or a less than optimal ground.
if you're running an onx6 and it is any bigger than a 10" bar, a 20A circuit isn't enough. (they pull approx 8.5A per 10" LED section.)
downforce137
In Diana
perhaps you have a short to ground that is popping the fuse. might not be the light itself, unless it has an internal short.. start by inspecting the wiring..
loupuleff
US
What truck you have ? What switch and wire you tied into ?
Sent from my SM-T813 using Tapatalk
loupuleff
US
You might have to use a relay off the up switch if your over 20 amps
Baja Designs
Sorry about the issue. Please give us a call at 800-422-5292 or email [email protected] and we'll help diagnose the issue.
What's the exact model? How is it wired?
Baja Designs
www.bajadesigns.com
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
I did the opposite on this truck. Previous Raptor had all Rigid lighting and I wasn't impressed with the output. Switched to BD for this truck and very impressed. Everything has been trouble free. No doubt they will get it sorted for you.
