CoronaRaptor
Another problem with your brakes could be that you went with 6 piston kits, I wanted that for my Stang, but was told not to, but to go with 4 piston ones, the reason I was told is because you don't make enough vacuum to operate them properly. This is 2nd hand advice so don't chew me out, it just seemed to make sense.
Curious, did you go with 6 piston on all 4 corners or just upgrade the fronts only?
