Axle Wrap/Transfer case hitting cab
Bulletnjm
New Jersey
Are there any marks or dents you can see? Can you post up some pictures from under the truck around the transfer case?
Deco12
No visible marks you cannot really see very well, Here are pics of the mount etc,
20mb image hosting
image ru
---------- Post added at 01:29 PM ---------- Previous post was at 01:28 PM ----------
photo sharing websites
---------- Post added at 01:30 PM ---------- Previous post was at 01:29 PM ----------
I cant really get pics of the top of the transfer case there is hardly any room. The other guy who was in that youtube video I posted said the dealer put a rubber block on top the transfer case to see and the banging under the console went away but im sure he still had the wheel hop
Deco12
Here a few pics I just took, I felt the under side of the body cannot feel any dents or see any scratches heres a few pics, one thing I noticed though is that my driveshaft shows alot more of the shaft vs my work truck which is a 2013 f150 crew cab 4wd 5.5ft bed, not sure if that means I need a spacer or not.
here are more pics
screen capture windows 7
img upload
and the other trucks shaft where it goes into transfer case
picture share
ProjecT 9
Houston
One Up Offroad traction bars. Like the ones I have on my truck. You can have them built with the 4" block included. Mine are for stock height just to help when I pull my boat but they allow for complete articulation. No loss in travel etc. I've had a OUO 525 series suspension on my last super duty. Highest quality you can imagine.
Couple videos showing axle wrap before and after traction bars.
http://youtu.be/k3h9QWrKN80
http://youtu.be/S86cnTd9XMk
WRCRaptor
Great Lakes
Ill contact pauls, I was hoping to stay away from traction bars,
So yall think that the banging under neath the truck is just from alot of axle wrap/wheel hop causing the tcase to twist and hit the floorboard?
Well I think it could be if all the mounts for the rest of the driveline are good. The only thing that may make a difference is that you have changed a lot of the angles by lifting, on my Bronco I also had new front and rear driveshafts made after installing traction bars with better u joints and some type of double joint thing on the front shaft. But that was 20 years ago and I don't remember yesterday so well some times!!
By the way Paul's HP did lots of work for me on a Mustang or 2 they are great!
cups
Fair Oaks, CA U.S.S.A.
Well I usually say dumb things but here ya go:
I seem to remember someone mentioning the angle the rear diff has with the driveshaft. I forget the fix to correct the angle.
And FWIW, I had very bad hop on the stock spring. Any speed bump would set it off unless I slowed to slow. I have added the National +2 HD springs. Have not had any hop on or off road since. My springs were part of RPG stage 3 kit that contains a frame support, hyd bump stop and the springs. I still run the stock Fox 2.5 shocks.
I've not had any issues with the National springs.
PropDr
Eugene, Oregon
The Raptor uses blocks between the rear springs and the axel; removing this blocks reduces wheel hop but will not eliminate it.
With your 4" blocks wheel hop is guaranteed.
Traction bars will eliminate it.
I believe that SVC has bars that can be installed without welding on the axel.
Deco12
how do you like the national springs?
I am thinking of just trying springs, I like the idea of a leaf pack in the first place over blocks.
I appreciate everyones responses and help, I think I will try to stop by the offroad shop and let them look also. Ill keep it updated
Thanks again
