Squatting Dog
Good to hear... Thanks for you persistance with this!
As for wiring, I ran it under the truck to the front passenger door sil and connected to the two wires I found in one of the generic f150online install threads.
Thread I linked earlier said:I just found out that if you wire up the Grey with Brown stripe and the Violet with Grey stripe then the tailgate will open with the SECOND press of the button. So it will open with all the passenger doors instead of with the drivers door.
This is for 2011 XLT Supercrew.
So there were no instruction with the one you bought. What I am trying to get at is, is the actuator a reverseable wire hookup meaning all you need to do is swap the two wires back and forth from positive to negative to make it move in and out.
If I only knew which wires dew.man used![]()
Thanks dew.man
