MTF
The Pop and Lock is a little expensive, but I believe it is built very well and will last a long time.
Now that I solved my situation, I would highly recommend this product.
It should take about 2 hours or less if you rush it, to install completely from start to finish.
I'm a Pro at this now!
Installing at least.
There are other F-150 out there that could not get the tailgate locks working,
be it Pop and Lock, Pace Edwards and DynoLock working either, this isn’t only Raptors!
So I would say if the wires do not work, then your alarm is not setup correctly even though it works fine
like mine did until I tried to add something.
Just to add: The alarm was installed correctly just not setup correctly.
I also want to tell everybody that Audiovox want's me to go back to the installer and
they will get the key fob working correctly with the Pace Edwards Electric BedLocker as well!!!
Using the #1 to open and #2 to close.
Then I will be as happy as a pig in _ _ _ _.
