ARH headers and CORSA extreme installed
JJ f150harley
Traverse City MI
That cleared it up for me. Thanks
Now I wish I got a local tune.
Anyone know of any good shops near traverse city mi? Haha
Sent from my DROID RAZR HD using Tapatalk
GotExhaust.com
Thank you. I think the issue is a combination of no cats And the tune. I really enjoyed that low end torque and didn't know that I would actually lose low end torque from the stock manifolds only that it would not improve as much as the 3/4 primary.
It's a give and take. Unless there's a major problem, you probably didn't lose any low end torque; but you probably didn't gain a whole lot below 2200 RPMs. When the torque spike does kick in, it's probably pulling harder than it was before, but is negated seat of the pants by the fact that the bottom end seems proportionally less powerful. 1 7/8 headers are fine for the Raptor 6.2L. You should see consistent gains throughout the RPM range. Also keep in mind that the Raptor isn't a drag car. It's gonna be a moose off the line pretty much regardless of what you do. You spend a lot more time cruising and on the highway, which due to the Raptor's 4.10 gears, will keep you right in the power band. Put on some cats and have your truck re-tuned.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
Yes I understand the raptor is a moose but what I'm saying is that with stock manifolds my truck wAs quicker off the line than the 17/8 and it gargles like it's gonna die shaking the hole truck from the lope
---------- Post added at 12:43 PM ---------- Previous post was at 12:41 PM ----------
Who can tune dyno is CA?
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
I contact ARH and five star. We're trying to figure out if the install was done incorrectly or if the tune is off. ARH stated that EVERYTHING should increase even bottom end.
JJ f150harley
Traverse City MI
I have my bottom end now. Just tested it 5min ago:) but that's after a few months. I do remember that at first I didn't have it either and the truck shook.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
I think the shop that installed may have reversed the front and rear 02 sensors. Checking on that now. The front sensor should be bigger than the rear and the rear sensor should neck down correct?
JJ f150harley
Traverse City MI
Yea check your computer for codes but put it back to stick tune before you do so that your codes show.
BRAPPPP
BRAPPPP
San Luis Obispo, Ca
Determined it must be an issue with the tune. Put the stock tune on and the gargling and bog went away. Gonna contact 5 star today
