GEN 2 Anyone notice how smooth tow/haul mode can be?
Toadster
Folsom, CA
Tried tow/haul mode the other day - not towing - damn it’s smooth... shifts feel instantaneous too and no skip shift bs
jaz13
I use it a lot without a trailer in the mountains because it keeps the truck from shifting into overdrive while coasting and allows better engine braking.
TXRaptor
Does your Whipple Stage 1 change the transmission or is it still the factory transmission tune?
Jeff-Ohio
Cincinnati
I have tried it for daily use, but switched back to the regular mode due to the strong engine breaking. If I could eliminate the engine breaking, I would probably use tow mode exclusively for daily driving.
Toadster
Toadster
Folsom, CA
It's changed/upgraded with FoMoCo updates since the stock code - over 1200 tweaks applied
---------- Post added at 12:58 PM ---------- Previous post was at 12:57 PM ----------
Yeah I wonder how well it would work at a dragstrip because the shifts are very short...
TYRCS
Traction control off in tow haul mode is legit, love how peppy the truck is and the truck goes through a smooth rpm range and it slows the truck down when you let off the gas so you don't burn through your breaks when driving fast, I have the TCM tune and it still skips gears in normal and sport mode, I just like the truck going through all the gears they way it does in tow haul mode and when you have a Borla Atak it sounds good too!
JohnyPython
Canada
I’ve used it for towing. It works as it should.
On its own, it’s like a shot of vitamins. Should be called Haul A$$ mode.
Joshua Krueger
texas
I need to try it. We have a suburban with the 10 speed and it shifts smooth al the time. Its night and day different.
Badgertits
Ma
Much different vehicle...different purpose, that being said while it was jointly developed w/ GM I feel like GM has had the greater “tranny building cred” than ford in recent history (not really saying much about either tho hence the JV) -& part of me wonders if GM didn’t hold back a few R&D hardware/software tweaks they learned along the way from previous 6/8 speed trannies....
96,883
60,831
Surfcat
