jabroni619
- Joined
- Jun 13, 2017
- Posts
- 2,057
- Reaction score
- 1,420
Jeez why get personal? I KNOW EXACTLY WHAT IM TALKING ABOUT! ITS MY TRUCK!!!! IM NOT SOME ******** YAHOO!!! To get the rear axle into Low 4WD ALL Raptors go through the center differential gears. A true AWD "Clutch Pack" in the center differential can be biased front or rear or true 100% power to front or rear! Also my truck will shift out of 4A when I choose Sport Mode and go to 2H. It will NOT go back 4A by turning the knob. Give me break! Maybe you should read your manual. The lock button on the 4x4 button is TRANSFER CASE LOCK.
Do you Twizzle Stix own an early 2017 Raptor Screw 802A with Torsen Front Diff? If not then shut your Front Door please. My Raptor's Build Date is January 2017 so the transfer case and / or traction control and / or 4A configuration is obviously different. My truck was an early production new car show truck with Grindstaff for Johnson City, TN. in March 2017.
Until YOU drive my truck don't tell me what my truck does OK? WTF? Don't project your ignorance onto my description of how my truck operates! And don't disrespect people who you disagree with you by calling them names! Its a true sign of low IQ! We are not in 5th grade anymore!!!
HT
Saying you don't have a clue isn't personal. It's a observable/verifiable fact. I don't need to drive your truck. Ford did not make yours differently then the thousands that came before, or after it. No one is saying the rear drive shaft isn't connected through the transfer case. The wet clutch packs however are driving the front wheels, not the rear. Again, you don't know what you're talking about. Period, end of story. You didn't even know how to use sport mode in 4A and thought the button was a "transfer case differential lock" whatever the **** that means.
Whats next? You're going to tell us you blew the welds on the manifold and have a stand alone fuel management system?
