Alternative Offroad No-Cut Hood Mount Light Brackets!!
Zman12
Gardner,Ks
We could do it for an extra cost, but in our experience Line-X compromises the stability of the brackets and makes them a lot more clunky. Kind of hard to explain but it can be done if you'd like
I am ver curious how could linex compromise the quality? Maybe I am just not understanding?
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
Yep my bad I have quality on the mind. But I am still confused with the stability comment.
Because the linex is textured it doesn't have as solid of a surface to mount to on the bottom, it's rocky and doesn't mate the same as powdercoat which is obviously as flat as possible. We just noticed it it's not a huge deal but I would never sell them linexed
Zman12
Gardner,Ks
I got you. Makes sense now. So if you want to linex either have it sprayed smooth on mounting face or don't spray that area at all.
AlternativeOffroad
AlternativeOffroad
Los Angeles, CA
Yep, and I would also leave the top portion where the light mounts flat as well. The flatter the mounting surface the better off you'll be
SVTBuckeye
Northern California
So it's only a $10 difference between Dually d2 driving beam and the Visionx light cannon kit. What are the pros/cons of d2 vs. light cannon?
