Alternative High-Beam Connection ?
Leadfoot2020
Louisiana
FordTechOne
Detroit
Okay, Hella makes a solid state relay.
http://hellahd.com/index.php/default/electrics/relays/mini-iso-relays/12v-spst/h41773001-931773987/
I can't find info on milliamps required to activate it though. If its low enough, could you use one of these, triggered by the high beam to then activate other relays? That way if you want to trigger 3 or 4 relays their milliamps wouldn't compound and overload the high beam BCM circuit.
Of all the possible ways to use a factory circuit to activate an aftermarket component, a solid state relay would be the safest.
2020Raptor
2020Raptor
South Central...NJ
Outstanding !
Thank you very much for your assists with this.
:chewie::chewie::chewie::chewie::chewie:
K223
Florida
I may want to put my S8 on the high beams as well. Just seems to make sense if possible. Curious to know if utilizing this type of relay off a factory circuit will be fine.
