Morimoto MotoControl - High-beam Issue
elav
Bay Area
Hello, I have a Gen 1, 2011 Ford Raptor that came with the original halogen headlights. I bought a used pair of OEM HID headlights and the Morimoto MotoControl so they will work with my existing headlight harness. The headlights work and I can flash the high-beams but I can't get the high-beams to stay on. I know that you pull the steering column lever towards you a little bit to flash your high-beams and pull it more to keep the high-beams on, but I can't recall if it was simply triggering a relay or if the lever stays in the outer position. I would find it odd that the lever broke at the same time (and I did replace it 2 years ago).
Some additional information...
1. I did disconnect the battery and removed it to access the ground point below the battery tray - could I have fried a fuse when it reconnected?
2. The Morimoto MotoControl harness was a little too short - so I cut the harness that goes over to the driver's side and extended it by 14". This is soldered and has heat shrink on each wire - I don't think this is the issue, but I figured I would mention everything associated with this project.
Thanks for guidance on how to identify the issue!
stevenstommyboy1
Menasha Wisconsin
I thought pulling towards you flashed and pushing the stalk forward to a fixed position engaged high beams continuously. I will have to go look on mine. Lol. Brain fart in action.
stevenstommyboy1
Menasha Wisconsin
When you push the stock to the front, it’s highbeam on constantly. When you pull it toward you slightly that’s just to flash the highbeams just checked it all.
It does lock in the forward position.
E
elav
Bay Area
Thanks - looks like my stock is broken and I just happened to notice this when I installed the HID headlights
