Mjolnir
Hello ducatisps,
How long did you have the AIRAID before you had the issue with the filter? I am thinking there may have been some mold release inside the flange that might be causing that.
We have had this kit and design out since 2010, and have NEVER had any reported issues of the filter falling off, on or off-road.
Take off the filter, clean the inside of the flange real good with brake cleaner, and that will give it a better bite. Also, just go snug, don't over tighten the hose clamp or that will force the filter to fall off over time.
Hello Ruger,
Good advice on cleaning the inside of the filter as well as the tube.
Please let me know how that works out for you. If this does not solve the issue, please call me direct at the number below.
Thanks,
David
1-800-498-6951 Ext. 712
David,
sorry to just get back to you on this, just saw it. What I found with my Airraid is that your instructions are incorrect. If you install the filter while the box and tube are in place you cannot get it to sit flush against the feeder tube, which causes it to fall off.
I took the whole thing out, built it on the ground, got a great seal between the filter, tube and clamp, then put the unit as a whole back into the truck.
I've done some off road pounding it with (nothing like the TRR mind you), but it appears to be solidly in place and not going anywhere now.
most of my drive is city streets, and I'm getting 10.9 mpg. I can get 15+ on the highway if I watch my right foot, but since I installed my Borla the truck on full honk sounds so cool it's costing me major gas mileage.
