never heard of em other than in the import world... pictures?I have the INJEN, am I the only one with a quality CAI? Lol!![]()
I stopped reading when you said the pipe was aluminum. They clearly don't know what the first letter of "CAI" stands for if they use a metal tube.
http://www.fordraptorforum.com/f24/airraid-installation-2011-6-2l-3085/
This is a good write-up on the AIRAID if I do say so myself.
I wouldn't consider the INJEN for two reasons:
- That aluminum alloy intake tube will get hot and the intake air will draw off that heat. Hot air expands and becomes less dense, and that will actually reduce the oxygen entering the engine to support combustion. Next time you go for a drive of any length in your Raptor, pop the hood and put your hand on the intake tube. Rubber, plastic, aluminum, or steel, you will find it very, very warm to the touch. In this application rubber and plastic is superior to metal because it will not absorb or transmit heat to the intake air as readily. Justvettn, you might want to consider insulating that tube as I have done.
- The INJEN design is not a cold air intake. It is wide open to the engine compartment and much of the air sucked into the intake system will be hot engine compartment air.
