Aftermarket Wheels
Pacific Wheel
Reno, NV
I ran across some Raceline Wheels (Shift 930B) that look interesting. Stock fitment in 17" yet only 26lbs w/2,500 load rating and the offset is +18.
I like the 8 lug shift but the 6 lug gets a cover cap. The new Racline Clutch is also 17x8.5 6x135 +18 and they're due in any day. No cover cap for this one.
The Raceline's have the same load rating as Method so I wouldn't be concerned.
iumbastu
Boston Area
Appreciate the follow up. Will the clutch be the same weight = 26lbs +\-? Send me a PM with pricing if you have a minute. Thank you for being the wheel guru for FRF!
Pacific Wheel
Reno, NV
The simulated beadlock will probably add a couple LBS. I'll shoot you a PM in a few.
Sid-X
Wondering if anyone has a set of hole shots on their truck? I am torn between the XD Holeshot and Robby Gordon 1. I am finding that depending on the offset the holeshot looks great or kind of like it came off of a collapsable spare.
Mkarban
Minnesota
Anyone know if we can fit a little wider tire on the truck? I was thinking of doing an 18x9 wheel with a 325/65 tire. Any problems with the larger footprint?
Pacific Wheel
Reno, NV
You'll be fine as long as you keep the offset in check. +12 to +20 should be good. Any lower you "might" have to trim a little plastic.
Tungsten
Fountain Hills, AZ
Has anybody seen these on a G2 yet? Thoughts on fitment...
XD SERIES HOSS 2 XD829SB
Bolt : 6x135
Offset : +18
Hub Size : 87.1
Load : 2500
Backspace : 5.71
Pacific Wheel
Reno, NV
Bolt : 6x135
Offset : +18
Hub Size : 87.1
Load : 2500
Backspace : 5.71
Offset looks good. They'd be very similar to these fitments. There are a few sets available too
