Add a sub problem
This is why I was suggesting a multimeter. You need to check if your voltage is dropping or even stable.
I wouldn’t have suspected either power or ground, but when I pulled the ground cable, many of the strands had frayed and broken off. lesson learned.
multi-meter positively id’d the problem as drop in voltage and giving the amp and sub clean power corrected the issue.
we’re several pages in, so let’s level set, shall we?
OP:
the recommended Pioneer 8" sub with Kenwood amp in my 802A B&O system. I used an AudioControl LC2i line converter to get the signal from the existing amp, convert to RCA inputs, then to new amp to power the Pioneer sub. I hooked it all up as other members have and there is lots of distortion and sounds completely terrible. I've rewired the whole system multiple times (changed dual voice coil series/parallel, changed speaker wire inputs, checked positive/negative amp connections, different line converter...) and still coming up empty. While the speaker is out of the enclosure, there is no distortion but as soon as it's in the box, the distortion comes back even at low levels.
So, my question is if people had to modify the existing box (other than moving plastic to fit speaker)? Did other people drill ports? Why is speaker distorting when mounted?
Have you removed the line converter and reverted to simple splicing to RCA inputs? @Toadster’s blog, and the F150 forum post detail this method.
here’s what know: your method didn’t work. Everyone else who’s done the sub mod has worked. what’s different?
also, did you get a mutimeter read out while the sub / amp was under load?
I’m not trying to make this personal here, just illustrate that this is a mod that literally dozens of us have done successfully. I even offered the troubleshooting I did to find the bum ground.
can you get some pics showing your setup? We’re kind of shooting in the dark without a light here.
if pics and the multi-meter and subsequent troubleshooting is going to be too much of an ask, bite the bullet and take it to pros.
Could not cost more than $300 to fix this. If your time is more valuable, it may be best to go this way now, before you fry something.
sherwood
sherwood
Santa Barbara, CA
OP:
I just hooked amp straight to battery positive/negative and used inputs from phone to RCA. Same result. I’m sure I’m ******** up but I've rewired and tried every combination but I'm hours in now without change.
My main question is that so far it seems everyone doing this mod is 2017. Anyone with 2018 B&O do this?
Video is setup as stated (yes I know speaker is not screwed in but previous tests show same “sound” regardless).
https://youtu.be/7Ul0I_jD9fw
sherwood
sherwood
Santa Barbara, CA
There’s not much to wiring but here is the pic. Red- battery positive
Black - battery negative
Missing is remote switch but was connected (amp was powered up)
Input is from rca to phone (also missing to take picture)
Speaker hooked up 4 ohm per instructions and confirmed with multimeter.
sherwood
sherwood
Santa Barbara, CA
